VSM failed to set an option on the socket used to communicate to a MLAG peer.Failure to set correct socket options will result in no or incorrect packets sent to the peer MLAG switch and will result in incorrect working of the MLAG feature
On dual-MSM systems try failing over to the backup MSM. Stackables or single MSM systems may require a reboot to correct the problem. If the issue persists, please escalate to engineering.
Error
Failed to set socket %option% error: %errormsg%(%err%)
| Name | Type |
| option | String |
| errormsg | String |
| err | sInt32 |
